PLEASE HELP 7.3 DRIVE N ME CRAZZZYYYY - Ford Powerstroke Diesel Forum
Old 12-18-2009, 05:57 AM
Question PLEASE HELP 7.3 DRIVE N ME CRAZZZYYYY
THIS IS TO ANY ONE THAT CAN HELP 01 F250 CC 7.3 ALL IVE DONE IS A BUILT TRANNY AND A POWER PUP THE OTHER DAY DRIVING ALONG SUM @$$ 0 CUTS ME OFF SO I STUFF IT AND THE CHECK ENGINE LIGHT COMES ON RUNNING ROUGH MISFIRE SKIP I GO TO MY GARAGE TAKE THE PROGRAMMER OUT TAKE THE BATT WIRES OFF TRY THIS AGAIN LIGHT STILL ON ONLY TIME IT WILL RUN GOOD IS WHEN ITS COLD AS SOON AS ITS WARM LIGHTS ON BACK TO SQUARE 1 CHANGED THE CAMSHAFT POS SENSOR TOOK THE BATT WIRES OFF THE TO FLASH THE COMP NO LUCK AND I CAN ONLY GET CODES FROM MY PROGAMMER NOT FROM A OBD SCAN TOOL PLEASE HELP BOUT TO GO CRAZYTHANKS TO ALL:
Old 12-18-2009, 06:26 AM
Wow dude, slow down. Your typing gave me a headache. Paragraphs and proper English are your friends.
Old 12-19-2009, 04:10 AM
Sorry i was in a rush yesterday morning. I was running late for work seeing how my trucks dead.i can only pull codes from my programmer not any scan tool.
These are the codes i got the first time i checked them.
0340,1316,0107,0603.
If any one can help me out with these thanks
Old 12-19-2009, 04:46 AM
Feedback Score: 5 reviews
This will get you moving in the right direction ~~~Trouble Codes List~~~
Old 12-19-2009, 05:23 AM
Thanks every lil bit helps but for you to take your time to look at my problems i appreciate it.I will let you know how i make out. Thanks again
Old 12-19-2009, 05:41 AM
No problem. I wish I could be of more help but I don't know too much about these trucks. Hopefully, someone else will chime in
Old 12-19-2009, 02:14 PM
i scanned my truck again this morning and i came up 1316 idm.Not sure if that has something to do with the harness under the valve cover.
I also inspected the harness above the drivers side valve cover and the was no wear.So if anyone can help me from her ewhat you may no or heard of will help thanks ...
Old 12-24-2009, 01:05 PM
same thing happened to me a while back and it was the wiring harness under the valve cover.
I tried to figure it out with no luck! I eventually had to limp into the shop
Old 12-25-2009, 04:52 AM
Powerstroke Junkie
You need to check the UVC harness on the inside of both VC's, sounds like one is loose or has a bad connection, look for burnt pins in the connector as well.
Old 12-25-2009, 06:03 AM
I changed to harness under the vc on the driverside. truck is back to normal thanks for all the help
