engine surge at fixed throtttle, engine light
I have a 99 F250 PSD with a 6 speed manual trans with 120K miles.
It's my first Diesel and I have had it about 2 years. Its a great truck, and I have had little trouble with it but recently developed an intermittant acceleration (surge) at fixed throttle during normal driving, followed occationally by a "service engine soon" light. Following the surge, all would be normal again and the warning light would then go out. I got the recall notices in the mail about when this first occured and had the cam sensor and cruise control pressure sensor replaced last week under the recalls. I had hoped that this would resolve the issue but no such luck... I searched the forum and have not found any threads that adress this specifically. So, is there a way the read the fault code without a reader like my previous truck (dakota). If not, can I use a standard OBDII reader to read the fault code or do I need to take it back to the dealer? Any ideas on what the problem could be? Thanks much. |
sometimes the ICP (injection control prressure) sensor can cause erratic stugff like that, as can the IPR (injection pressure regulator). need to get those codes, a reg. OBD II won't work, either take it to a dealer or mechanic, or look up AE software AutoEnginuity® - OBD2 Scan Tool - Professional PC and PDA Diagnostics get those codes and post em up so we know where to start pointing ya
You picked IanStew
Code 1280 Injector Control Pressure Sensor |
