Help - Ford Powerstroke Diesel Forum
Old 03-22-2007, 12:57 PM
Help
I keep getting the same code over and over injector control pressure above or below desired when i get it the truck runs like crap. i can shut my truck off and rite back on and it is fine. when i have the problem my ses lite flashes at me
Old 03-22-2007, 01:01 PM
Desert Shield/Storm Vet
Do you have a chip or are you tuned up?
Old 03-22-2007, 01:04 PM
nope bone stock rite now but will do same with programmer
Old 03-22-2007, 01:11 PM
Yeah its the 1211 code right? That usually means your hpop can't keep up with the oil demands for your injectors. Usually that happens when you chip it. Hopefully someone smarter then me will chime in.
Old 03-22-2007, 01:14 PM
it has no chip in it now when it does it
Old 03-22-2007, 01:22 PM
Here is some info for ya:
DTC P1211 indicates that injection control pressure was above or below commanded desired pressure during self test mode.
Possible causes:
incorrect oil or viscosity
poor oil quality
gel fuel/no fuel
low fuel pressure
damaged IPR valve
high-pressure oil system leak
damaged high-pressure oil pump
damaged PCM
Verify correct oil quality/viscosity and correct fuel grade are being used for the temperature conditions.
Old 03-22-2007, 01:33 PM
fuel and oil is fine
Old 03-22-2007, 01:39 PM
Yeah sorry Dukey I can't help ya beyond this point! Your oil is full your not low on oil? Someone will chime in with some help
Old 03-22-2007, 01:43 PM
yep full not even a hair low
Old 03-22-2007, 01:44 PM
mine was doing the same thing at around 50,000 and it ended up being the tranny speed sensor. Hope this can help you.
