Help 96 PSD won't start - Ford Powerstroke Diesel Forum
Old 03-21-2007, 11:14 PM
I drove my truck over the weekend and tried to start it up today and I ran the batteries dead turning the motor over with out the truck starting. What could cause this? I already replaced the glow plug module and I bought new glow plugs and plan on installing them tomorrow. I also bought two new batteries and will put those in tomorrow also. When I try to start the truck it doesn't even try to start, the glow plug relay gets really hot and a little smoke comes out of the exhaust side of the turbo. Can anyone point me in the right direction on getting my truck running again? Would be appreciated, thanks!
Old 03-22-2007, 03:39 AM
Powerstroke Techie
Since you already bought the glow plug, go ahead and install them, while you have the valve covers off, check the UVC harness's. They are known for melting. If you find one melted it will need to be replaced. If it is melted you will need to check the engine wiring harness side of the connector, if it is melted also you will need to replace the harness or find a repair kit for the harness, I think Oregon Fuel Injection sells them or check one of the vendors here.
Old 03-22-2007, 10:35 AM
Thanks, I will check it today when I put the glow plugs in.
Old 03-22-2007, 11:15 AM
Almostdunfukinwidit
Does the tach move when you crank it over CPS maybe
Old 03-22-2007, 12:16 PM
ADMIN AND TECH
is the oil level low and agree with quadracer does the tach move when spining over ,if batteries are that weak ,it wont start either, has to spin fast enough to start , does the wait to start light come on
Old 03-23-2007, 12:03 AM
well, I got it running, but it is running pretty bad. I replaced the glow plugs on the passenger side and saw the harness to the 2 front glow plugs and injectors was melted. I went to the stealership and dropped $65 on a new harness. I also put two new optima batteries in it and tried to crank it over. At that point it wouldn't fire up. I got some ether and got it to start finally. And it was running pretty rough, no power at all. I drove to the gas station and put some fresh fuel in it and the truck stalled when I pulled into the station. Started it back up, got fuel and drove it home. On the way home it barley hit 65 going up hill on the freeway.
What do you guys think is wrong with my truck? I am going to change the other glow plugs tomorrow and see if it helps but I think something else is wrong with it...
Old 03-23-2007, 12:12 AM
try the cam shaft sensor . it's just below the water pump on front of the engine
Old 03-23-2007, 03:05 AM
ADMIN AND TECH
glow plugs wil not efect runing at all just helps cranking , need to run more diag ,before buying any more parts , fuel pressure test, run codes , to see if you have any
Old 03-23-2007, 09:53 AM
I have a gas fuel pressure tester, will this work for diesel also or is a special tool needed? And where do I check the codes at? I have an OBD2 scanner but I can't find a diagnostic port under the dash...
Old 03-23-2007, 10:52 AM
ADMIN AND TECH
yes that gauge should work fine ,fuel pess. needs to be 55 give or take a few pounds , should climb gradually to that , and obd 11 port should be to the right side of the dash below the glove box ,aiming down
