7.3 4x4 OIL PAN REPLACEMENT - Ford Powerstroke Diesel Forum
post #1 of 11 Old 12-03-2009, 06:00 PM Thread Starter
Smile 7.3 4x4 OIL PAN REPLACEMENT
Hi,
While I was checking the underside of my truck I noticed the oil pan is all rusted and looks bad.
What does it take to replace the oil pan on a F-250 4x4 7.3? Engine off mounts? Total removal of engine? Drop front axle???
Thanks,
Mike
mike forte is offline
post #2 of 11 Old 12-03-2009, 06:02 PM
BIGBILL105 45's Avatar
Engine removal. Got mine out right now sadly lol.
PM ME FOR VINYL DECALS!
SOLD!!!!!
ARP head studs
4 inch down pipe
5 inch straight pipe
ts 6 pos chip
foil delete w/ polished IC pipes
ugly step delete
2% tint
black lariat rims
35 inch Pro Comp Xterrains
7 inch in dash dvd player
remote starter
16.265
BIGBILL105 45 is offline
post #3 of 11 Old 12-03-2009, 06:41 PM
Quoted: 5 Post(s)
remove engine, turn upside down, so new sealant cures for 24 hrs
Originally Posted by Ianstew
There is a difference in a government acting responsibly within their powers, and a government that just decides what their powers are and what responsibility means based on political whimsy.
ianstew is offline
post #4 of 11 Old 12-03-2009, 07:27 PM
eeek. im glad i live in ca. no rust here!
Dietoremain is offline
post #5 of 11 Old 12-04-2009, 05:11 AM
Quoted: 157 Post(s)
Feedback Score: 3 reviews
Maybe some POR-15 for now?
NoRalPh is offline
post #6 of 11 Old 12-04-2009, 03:53 PM
2 things:
First, has anyone wire brushed the oil pan rust and then applied Rustoleum rust converter? Obviously the pan rusts from outside to inside and I would imagine if the metal is not paper thin a converter should work fairly well. The Rustoleum converter works WAY better than Rust-Mort.
Secondly, if you do need to replace the oil pan, shouldn't you be able to remove the motor mount bolts, the trans crossmember bolt and jack the engine up high enough? I know its been done on F150's this way for years (obviously the exhaust has to be removed)
robertwhite is offline
post #7 of 11 Old 12-04-2009, 10:25 PM
Quoted: 5 Post(s)
The engine has to be turned upside down for 24 hours for the sealant to cure. If you do not seal it correctly, it will leak. The only way to guarantee no leaks is to pull the engine.
ianstew is offline
post #8 of 11 Old 12-05-2009, 03:30 AM
Exactly. The guy who owned my truck before me tried to fix it without pulling the engine. He cut the cross member out and dropped the oil pan, replaced the oil pan with a new one and went to town the the grey RTV sealant. Now I got the truck, it leaks now from where the oil contaminated the sealant. I got the engine out now doing it the right way.
SOLD!!!!!
ARP head studs
4 inch down pipe
ts 6 pos chip
ugly step delete
2% tint
black lariat rims
remote starter
16.265
post #9 of 11 Old 12-05-2009, 06:19 AM
What sealant is used? There HAS to be another way other than pulling the motor and turning it upside down. Ford doesn't have a monopoly on oil pan replacement from rust or damage. Why would you not be able to remove the pan and leave it off for a day or two in order to let all the oil drain out?
post #10 of 11 Old 12-05-2009, 06:38 AM
choupique108's Avatar
If you want it done right you have to pull the motor if you want it to leak you can do it with the motor in the truck.
1997 Single Cab Dually, S366 w/ Irate mount and plenums, EFuel, Intercooler, P.I.S 175/80s, Corbeau seats w 08 console, 19.5s, 6637, Black Interior with swede headliner and visors, Custom badges, Flight Fab Traction Bars.
choupique108 is offline
