haven't started my truck in 4 days start it tonight and the SES light stays on - Ford Powerstroke Diesel Forum
 4Likes
post #1 of 48 Old 05-10-2017, 04:41 PM Thread Starter
Strokedrd's Avatar
Quoted: 17 Post(s)
So I haven't started my truck in 4 days start it tonight and the SES light stays on... Runs for a min or two then dies.. Restarts fine but then dies again I do not have access to a scanner at the moment.. here is the link to a video of the whole sequence.. please listen closely something sounds off
All input is appreciated
Sent from my iPhone using Tapatalk
Strokedrd is offline
post #2 of 48 Old 05-11-2017, 02:12 AM
SUPER-STROKE's Avatar
Quoted: 3 Post(s)
Check cam position sensor and plug. If sensor is not bad, most likely the plug/pigtail is shot and shorting out.
Second, I can not stress this enough, check out all grounds and connections...
Check all electrical harness hard shells on left fenderwell near the brake booster.
Sent from my iPad using Tapatalk
SUPER-STROKE is offline
post #3 of 48 Old 05-11-2017, 03:01 AM Thread Starter
Strokedrd's Avatar
Quoted: 17 Post(s)
OK will do I'll keep u posted
post #4 of 48 Old 05-11-2017, 03:05 AM
Quoted: 3 Post(s)
I would also check out the plug for the turbo pedestal valve. If one of those plugs/pigtails are bad they can short out and draw too much power and shut down the PCM and therefore shut the truck down.
post #5 of 48 Old 05-11-2017, 03:05 AM Thread Starter
Strokedrd's Avatar
Quoted: 17 Post(s)
Will do
post #6 of 48 Old 05-11-2017, 03:42 AM Thread Starter
Strokedrd's Avatar
Quoted: 17 Post(s)
OK so now I'm real confused.. Started it this morning to see if it was still acting up... No SES light and had been running for 15 min...wth
post #7 of 48 Old 05-11-2017, 03:45 AM Thread Starter
Strokedrd's Avatar
Quoted: 17 Post(s)
Also do anyone hear anything that sounds off??
post #8 of 48 Old 05-11-2017, 03:54 AM
Heavy_GD's Avatar
Quoted: 1656 Post(s)
Feedback Score: 3 reviews
Low battery.
GD
Originally Posted by Patriot View Post
...because Patriot.
Heavy_GD is offline
post #9 of 48 Old 05-11-2017, 04:01 AM Thread Starter
Strokedrd's Avatar
Quoted: 17 Post(s)
I'll test them..
post #10 of 48 Old 05-11-2017, 08:42 AM
Slimline's Avatar
The cam sensor can shut down a motor just like that then start up fine.
Sent from my LG-H831 using Tapatalk
1997 f250 extended can SRW 4x4 7.3 turbo, e4od (mildly built up)
DP Tuner F6 tuned by Jody
Rosewood stage 2 180/80 injectors
Diy intercooled
efuel conversion
t500 hpop
BHAF
4" straight pipe
Swamps IDM
Glowshift pyro, boost, tranny temp and fuel pressure gauges
AIC mod
Diesel site coolant filter
2" body lift and 35" Wrangler Dura Trac's
For Sale: E4od "Punisher" valvebody $150 obo
Slimline is offline
