rough idol and no power - Ford Powerstroke Diesel Forum
post #1 of 25 Old 03-15-2007, 09:10 AM Thread Starter
my 97 psd is idoling rough and has no power. my whole truck shakes when driving it. it shakes so bad it that it is rattling bolts loose. if someone could help i would appricate it. thanks
Jason73 is offline
post #2 of 25 Old 03-15-2007, 10:07 AM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 30 Post(s)
I would bet on a fuel issue. Change your filters first and see if that helps. Sounds like you have a lack of fuel to one or more injectors. Could be bad injectors but do the filters and report back.
2003 6.0 F350 dually on high cholesterol fuel (WVO)
2000 7.3 Excursion also on a high cholesterol fuel
Clay Henry is offline
post #3 of 25 Old 03-15-2007, 10:26 AM
ADMIN AND TECH
SCUFFY828's Avatar
is the check engine light coming on at all
ITS STOCK
SCUFFY828 is offline
post #4 of 25 Old 03-15-2007, 11:00 AM Thread Starter
no the check engine light isnt on. im gonna change the filter and see what happens
Jason73 is offline
post #5 of 25 Old 03-15-2007, 11:42 AM Thread Starter
fuel filter didnt help. if i had bad injectors it would be blowing white smoke right?
Jason73 is offline
post #6 of 25 Old 03-15-2007, 12:14 PM
ADMIN AND TECH
SCUFFY828's Avatar
how bad is the smoke , if its real bad you could have injector problems for sure
ITS STOCK
post #7 of 25 Old 03-15-2007, 12:19 PM Thread Starter
it aint smokin at all i was wondering if my injectors where bad and if that was a way to tell. my oil level was 2 quarts low so i went ahead and changed it earler today too. but it didnt help either. Could the oil burning have somethin to do with it because it hasnt leaked a drop?
Jason73 is offline
post #8 of 25 Old 03-15-2007, 12:21 PM
ADMIN AND TECH
SCUFFY828's Avatar
i would have codes pulled first , and also would run a fuel pressure test , before i went any farther, dont want to guess
ITS STOCK
post #9 of 25 Old 03-15-2007, 01:15 PM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 30 Post(s)
Did you check the oil in the HPOP?
Sounds to me like low fuel pressure for sure.
post #10 of 25 Old 03-15-2007, 01:31 PM
00ba250's Avatar
mine did the same thing some of my filter and came apart and messed up my injectors.
TURBO GARRETT GTP38R
AIRAID COLD AIR KIT
ITP OVERBOOST KIT
TS 6 POSITION CHIP
XENON BLUE LIGHTS AND FOGS
FENDER FLARES
BILLETT GRILL
8" PRO COMP LIFT KIT
PRO COMP STABILIZERS
37" NITTO TERRA GRAPPLERS
STRAIGHT PIPE TURBO TO REAR
NO CATS OR MUFFLERS
SONNAX KIT
4 MEMPHIS 6X9S
2 KICKER 12" SUBS
1500 WATT AMPS
TV/PSP ON THE DASH
AUTO METER ULTRA LITE GUAGES
BOOST, TRANNY, EGT
18" AMERICAN RACING RIMS WITH LOCKS
REMOTE START WITH ALARM SYSTEM
BILLETT TORQUE CONV
00ba250 is offline
