Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Motor Problems
Old 11-06-2009, 04:52 PM
stroker101 stroker101 is offline
Need help got blue smoke rough running till warm!!!
i got a 99 psd 7.3 its got a afe intake and exhaust im running a superchip in it.......I have been having problems with it for the past month its started out as just not running 100 percent till it was completely warmed up now its to the point warm or cold it runs ****ty..........If i touch the pedal before it is warm completly it will rev up but will stall after...and blow blue smoke now over 2500rpm driving and it will cut out loos all power and try stalling ill hold it to the floor and t will bellow blue smoke till it clears out and then take off ....if it dont clear out i got to sitt there and crank it for a while for it to start back up and keep pumping the throttle and it start and rough idle then go back to normal need help got lots of coodes....
p1209 injector control peak press change test fault
p0478 exhaust pressure control valve circuit high
p1282 inj control pressur higher than desired
p1212 Inj control pressur lower than expected (engine cranking)
p0470 Exhaust pressure sensor circuit malfunction...
p1211 inj control pressure beyond desired (engine running)
PLEASE HELP
Old 11-06-2009, 05:32 PM
RollinEarly99 RollinEarly99 is offline
The exhaust codes you have shouldn't be the problem since most people get those when they change there exhaust. But the other problems might be pointing to an IDM going out... I'm sure someone is going to chime in that has had this problem.
Old 11-06-2009, 08:10 PM
what is a IDM and Thanks for the quick reply
Old 11-06-2009, 09:04 PM
It feels as iff its getting cut out on fuel like its running out of fuel....it will idle but if i hold it at like 2 2500 for a little bit it will slowly start to drop rpms and then act as if it is running out of fuel and pour blue smoke as it is running out .....to me it seems like a fuel problem where is is starving for fuel someone please help.......
Old 11-08-2009, 04:51 PM
I belive it stands for injector drive module, it basically tells the injectors what to do...
