Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Motor Problems
Old 11-05-2009, 06:10 AM
Dudenhymer Dudenhymer is offline
Where is the HPOP?
Hello, I'm chasing an oil leak on my 2003 7.3 There is oil all over the dust shild cover between the tranny and motor. Looks to be running down from the back side of the motor somewhere. I've been told to look at the HPOP for O-ring leak. Where exactly is it located and how do I get to it?? Thank you.
Old 11-05-2009, 06:12 AM
choupique108 choupique108 is offline
In search of 20s
Location: Lake Charles, Louisiana (currently Shawano, WI)
i have the same leak and i cant find it.
Old 11-05-2009, 06:35 AM
NoRalPh NoRalPh is offline
It's between the fuel filter and the fan.
Old 11-05-2009, 06:43 AM
Wide Right Wide Right is offline
Good videos here on chasing down oil leaks on the 7.3:
POWERSTROKEHELP.COM - The Information Source for Ford Power Stroke Diesel Owners
Common sources of oil leaks are the HPOP, turbo pedestal, and EBPV. If it's the HPOP, you can get a kit on eBay with the o-rings, loctite, and instructions - all for $15. Also check the HPOP lines and fittings. Good luck.
