Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Motor Problems
Old 11-04-2009, 10:27 AM
tdanos@cox.net tdanos@cox.net is offline
Oil film in Coolant tank
Hello....I am new here and this is my first powerstroke 2000 F350 Old truck was 1992 F350 7.3 non turbo. I have a little oil in the coolant tank. Mostly a film on the surface no more than a 1/2 teaspoon. Truck runs great and has no water in oil. 187000mi still stock. How concerned should i be? Any ideas what is causing this?
P.S.- This site is GREAT. Thanks Troy
Old 11-06-2009, 04:11 PM
ANYONE??IDEAS
Old 11-07-2009, 11:07 AM
jnmgraff jnmgraff is offline
havin the same problem was told leaky injector seal or cracked injector? i would love some more info though!
Old 11-09-2009, 03:09 PM
wags1992 wags1992 is offline
See if you can smell it. More than likely it is actually fuel in the coolant. That is usally caused by the injector cup cracking or the head cracking. I would try to smell it and if it smells like fuel then take it to your local FORD DEALER. I cant stress FORD DEALER enough.
Old 11-10-2009, 08:12 AM
Ricemiester Ricemiester is offline
if its engine oil it would be the oil cooler on the side of the engine on the drivers side
