Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Motor Problems
Old 11-04-2009, 05:26 AM
cpayne6335 cpayne6335 is offline
help with oil leak?
Hey all,
I thought I patched my massive oil leak. It is coming out of the dipstick flange on the oil pan!!!!! I have cleaned it, put rtv around it, jb weld, you name it, I have done it. Still it is leaking a bunch of oil.
I do not have the time to pull the engine to fix this. I have tried to unscrew the flange and that was a no go also. I tried this for the international kit.
I have been fighting this leak for a week + and am about done fooling with it.
Old 11-04-2009, 10:24 AM
JLR350 JLR350 is offline
Oil dipstick Flange Leak
I had the same problem with my 99 powerstroke, I was able to unscrew the big flange nut off of the oil pan, clean it all very good, and then I put a generous amount of RTV silicone around it and put the nut back on good and tight. I then let it sit for 24hrs. That was last January; I use my truck pulling hard at least 3 to 4 days a week and have not had a problem since. The main thing is getting it very clean and letting it sit to make sure the silicone is very very dry. I tried it a couple times without it being super clean and not letting it sit before I finally got it fixed right.
Old 11-04-2009, 11:14 AM
was it hard to get the nut off? I had a pipe wrench on it, and it would not turn...... I guess I will try it agian tonight and see what I can get done... thanks for the help JLR.
Old 11-04-2009, 06:46 PM
Oil Leak
Chris, I cannot remember what I used to remove the nut. I do remember it was not that easy. I am thinking that I used a large pair of channel locks. Lemme know how it goes, good luck. Jared
Old 11-04-2009, 08:59 PM
could not get nut off... broke a tool, lost my mind.... and stoped for a while, then tried some more rtv. I injected some under the nut, and then covered the rest of the area up with rtv. (the starter is off for more room)
could a valve cover leak about 4 qts in 20 miles? I need to degrease the engine again and tripe check the hpop lines, turbo parts.......
is there any other oil lines in this engine that could leak?
Thanks Chris
Old 11-04-2009, 09:02 PM
Hey, here is a redneck idea..... anyone try and weld the nut to the pan???? Still debating that one, but time for bed....lol
Old 11-04-2009, 11:43 PM
adfields adfields is offline
Plumbers epoxy may work for you, comes in a stick at Home Depot and the like. You cut off a hunk, kneed it till its all one color, and slap it to a very clean surface. Use starting fluid or brake cleaner to be sure all the oil is gone and don’t touch with oily fingers. I did a structural repair inside a T-case with it where the chain front output bearing support broke it 3 years ago. To my amazement it is still holding and I have hammered on it a bunch, I think it’s now stronger than when it was new.
I have heard of a plug or something in the back of the valve cover leaking that is very hard to find so you may want to look around up there also.
Old 11-05-2009, 05:14 PM
update... RTV failed again..... so I cleaned it all off and got a "metal bonding agent" let it set up, and it leaked! but in a differt spot this time, so I will clean that area and reapply the stuff..... it does not leak as much, but over time I could blow up the engine.... so I will try again.... I did look at the plumbers stick stuff.... that is the next step I think, or just bite the bullet and put a new oil pan on......
Old 11-05-2009, 05:42 PM
Flyin5 Flyin5 is offline
have you checked your dipstick tube o-ring? I chased my oil leak around the flange for a while before i realized half of my leak was from the dipstick tube itself.
Old 11-05-2009, 06:39 PM
oil leak
Yes, My old tube was rusty and came out in 3 pieces, so I have a new tube, new oring, and a bunch of rtv for a extra seal. at first that is what I tought, so I was going to replace the seal, but the tube just could not get out, and started to break on me.
