Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Motor Problems
Old 10-30-2009, 03:53 PM
RaZe RaZe is online now
DEAD BATTERY!! WHICH ONE DO I REPLACE??
Hey guys my truck wont turn over at all and the battery is dead according to the batter gauge. NOW there are 2 batterys .......which one do i replace? both? or the one by the intake? or the one by the passenger side???
can i get a new battery at oreillys????
please help i need to use my truck tonight! thansks
Old 10-30-2009, 03:55 PM
Tony V Tony V is offline
Sweet Diesel Smell
In my experiences when one goes bad the other will follow becuase when that one was going bad the other had to make up for the other. I'd get both sucks but helps in the long run!
Old 10-30-2009, 03:56 PM
03dieselman 03dieselman is offline
Both
Old 10-30-2009, 03:57 PM
1tonpower 1tonpower is online now
replace both at the same time. if you only replace one, the week battery will always be drawing the good one down
ahh ****!!!
k thanks guys.
is there a certain type i have to get or what?
Old 10-30-2009, 04:17 PM
MINIs1094 MINIs1094 is offline
Try and go with a red top Optima. Gel cells work a lot better and will take a beating as well. Just make sure that you get the battery hold down adapters. I have two in my truck and I dont every worry about the electrical in it.
Old 10-30-2009, 04:57 PM
4ds4me 4ds4me is offline
Pull the batteries and have them tested, you may have an alternator issue and your batteries are just fine.
Old 10-31-2009, 01:03 AM
well the turnovers have gradually became slower and now theres nothing.
and plus the batter gauge shows that there is no voltage at all. so i think its the batteries , but thanks.
Old 10-31-2009, 01:36 AM
orng1 orng1 is offline
I got my truck to kill the batteries until they were gone, really gone. I emptied out the tank with the pump and left it running for a long time. I left the batteries charging and now they are fine. Maybe a little worse for the wear but they still turno the truck over fine. Take the batteries to be charged and tested and if they are good test the alternator. I do think that you may need new batteries but they don't charge anything at a lot of places to test them and it's better than paying for batteries. It's better than having to replace them when they die again a few weeks later because it was the alternator the entire time.
Old 10-31-2009, 08:01 PM
StarDriver StarDriver is offline
A way to test the batteries is put a voltage meter on either battery, put the volt meter where you can see it from the driver's seat, read your voltage, then turn the key switch to "on", if the voltage drops and is very slow to come back,(If it stays below 11 volts, it propbably won't start.) your batteries are shot. They will drop voltage as the glow plugs cycle, but if your batteries are good, when the glow plugs shut off, it should go right back to 12+ volts.
Always replace both batteries at the same time.
