Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Motor Problems
Old 10-29-2009, 02:02 PM
colo00F250 colo00F250 is offline
Need help with fuel leak
When the engine is running, fuel leaks from the fuel/water separator tube. From what I have read on some threads is that some o rings in the bowl need replaced. Can I do this myself? and why do I keep getting shocked by the glow plug wires when I open the fuel/water separator line. Im no mechanic but I dont remember it doing that before.
Thanks for your help.
Deanna
Old 11-08-2009, 07:16 PM
TenMore TenMore is offline
yes you can doit your self 20 min less than $5.00 Welcome to guzzle's Ford PSD Maintenance Web Page as to the shock no idea
Old 11-08-2009, 07:17 PM
Tony V Tony V is offline
Sweet Diesel Smell
Yes you can urself.
Old 11-09-2009, 12:37 PM
fuel leak
Hey thanks TenMore. I almost gave up getting a reply on this one, I really appreciate it.
Deanna
Old 11-09-2009, 04:11 PM
it might take a little longer than 20 min but its easy......kinda tight back there......and take a rag and spread it out back there as much as you can to catch any little part u might drop trust me its a pain to find it if you do drop it good luck
Old 11-09-2009, 04:14 PM
melmount melmount is offline
4 screws hold on the valve, they are torx, I think t25. There are 3 O-rings.
