Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Motor Problems
  #11 (permalink)
Old 10-29-2009, 01:04 PM
superduty4x4 superduty4x4 is offline
If it's labeled as a 99, it should have split shots as far as I know.
  #12 (permalink)
Old 10-29-2009, 03:35 PM
rpm-inc rpm-inc is offline
A truck pcm will NOT work in a van. Engine wise, it will start and run fine. But the trans part of it is way different. You need a van pcm for the van.
  #13 (permalink)
Old 10-29-2009, 07:55 PM
elibenson elibenson is offline
I figured that part. When I say "truck" I usually mean van. In EMS, anything that gets you from place to place is a "truck". The reason why I asked in the F-series section instead of the E-series section is because there is a lot more knowledge to be had here. I figured that the same information that I gleaned here about F-series trucks would work for E-series vans.
As some one posted earlier, it *should* work to use a newer (van) PCM in an older van, provided it had split-shot injectors. I tried this today, and it did in fact work. The only thing that is a little screwy is that the newer truck has an intake air heater, whereas the older one does not. It throws a code, but it doesn't set the MIL. I can live with that.
It remains to be seen if this actually fixes my original problem. One positive sign is that all the codes that I got from the old PCM continuously didn't appear when I ran the truck with the new PCM. The only code I get now (a new code I've never seen before) is for the "Intake Air Heater Low Input), which makes sense since in '98 they didn't use them.
  #14 (permalink)
Old 10-31-2009, 02:43 PM
RRonning1984 RRonning1984 is offline
Heavy Equipment 911
Originally Posted by Dave View Post
You sure you dont mean Car-Part.com--Used Auto Parts Market Ryan?
Yea, actually that's exactly what I meant. Thanks
