Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Motor Problems
Old 10-23-2009, 03:50 PM
mustangvirgil mustangvirgil is offline
2002 f-350 keeps dying
i have a 2002, f-350 w/ a 7.3 liter and while driving the truck will shut off and will restart immeditley w/ no problem. other than that the tuck runs fine. when it shuts off, it acts like you've turned the key off....no sputtering or anything. the cam sensors been changed, fuel pumps been changed, truck has 300,000 miles on it.
Old 10-23-2009, 03:51 PM
no-tel-in no-tel-in is offline
any codes?
Old 10-23-2009, 04:00 PM
how do you get the codes
Old 10-23-2009, 04:08 PM
sea71 sea71 is offline
I vote to change the CPS(cam position sensor). There is a recall on it from Ford. Go ask your dealer.
Old 10-23-2009, 04:09 PM
hook up the obd2 port to a code reader, or tuner, they will read codes
Old 10-24-2009, 11:57 AM
it is fixed it was the left inj. harness shorting out
Old 10-28-2009, 06:01 PM
snowman snowman is offline
Where did the harness short out at? My 02 excursion will run and then will die at a idle or while coasting ? snowman
Old 11-06-2009, 03:02 AM
sorry it took me so long to get back to you. it shorted out on the main harness where it plugs into the valve cover gasket. it's possible that could also be your problem. let me know what you figure out.
