My 99 died. - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-10-2007, 06:35 PM Thread Starter
My 99 died.
I was on my way home the other night and it died like it would have ran out of fuel. I turned the key on and off a few times and it started and ran for about 1/4 mile and died and hasn't ran since. So I asked around and checked the fuses, fuel filter, unplugged the 6 pos. switch and nothing. So then I changed the CPS. Now when I turn the key to the on position my "Wait to Start" light doesn't come on and the"Service Engine Soon "light is on and still won't start? What have I done now?
991/2 F-250 6 spd
No muffler, K&N air filter, stock otherwise.
99 Silverado Reg.cab p/u
5.3 whole lota other stuff
Best 1/4 time = 12.94 @102
kcrochet is offline
post #2 of 7 Old 03-11-2007, 06:33 AM
BIG TRUCK, SMALL DRIVER
pipelayerjdh's Avatar
Have you checked the fuel pressure?
Derrick
'97 F-350 "FORDOR" 4X4 (Dually Conversion, Shackle Reversal, Technicooler , Auto Meter Gauges, 4" DIY Dual Exhaust w/ '08 tips,
, Wicked Wheel 2, 360 thrust bearing, Homemade E-fuel conversion, Wildman Chip,
) 230K and counting...
pipelayerjdh is offline
post #3 of 7 Old 03-11-2007, 05:21 PM Thread Starter
Well when I drained the fuel filter I left the yellow bleed opened and turned the key on and fuel started going everywhere so I figured that it had fuel.
991/2 F-250 6 spd
kcrochet is offline
post #4 of 7 Old 03-11-2007, 05:23 PM
Desert Shield/Storm Vet
vitalidle's Avatar
Hmm see if you can pull any codes.
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
post #5 of 7 Old 03-11-2007, 09:53 PM
99Smokin73Stroker's Avatar
Send a message via AIM to 99Smokin73Stroker Send a message via Yahoo to 99Smokin73Stroker
If you have a CEL then you should have a code. Find out what it/they are.
2005 F350 XLT FX4. 2.5" leveling kit, 03 turbo, 4" MBRP Turbo-back, 58v FICM, SCT X4, Irate Diesel coolant filter
99Smokin73Stroker is offline
post #6 of 7 Old 03-12-2007, 03:13 AM
ADMIN AND TECH
SCUFFY828's Avatar
check fuse for fuel heater ,if wait to start light isnt coming on then the pcm has no power, fuel heater is shorted probably
ITS STOCK
SCUFFY828 is offline
post #7 of 7 Old 03-19-2007, 07:12 AM
Send a message via AIM to gliddec176
check the cam positioning senser sometimes they are tempermental like that
gliddec176 is offline
