truck smoking - Ford Powerstroke Diesel Forum
Old 03-10-2007, 09:14 AM
truck smoking
OK, I just had my turbo pedistal repaired... new o rings and seals and spring?...ugh the dealer did it....Should have did it myself, but I had no time....
Anyways...now my truck is puffing white smoke....when it sits at an idle...and when you hit the acelerator and also normal driving....a good amount of it too..
I had a superchip running in it...Now I am running stock...I pulled the chip before it went to the dealer.....Anyone have an suggestions?
2000 f-250 with a 7.3
Old 03-12-2007, 03:11 PM
Can't help you, but I can bump this up for you.
Gord.
Old 03-14-2007, 05:21 AM
ok, dealer now states the turbo is bad.... it is sucking oil into the turbo now that the pedistal seals are good....
is this right? are there any aftermarket turbo's cheaper than $1400 bucks..
Old 03-14-2007, 05:33 AM
HardLuck Case of the Year
Send a message via AIM to Ditty Send a message via Yahoo to Ditty
I tell you what...this sounds a little weird. You weren't puking white smoke before they worked on it. (right?) They "fixed" the O rings. And now your truck is shooting out white smoke. Sounds like THEY goofed it. I'd be asking THEM to pay for the turbo repair. Sounds like THEY either put someone else's turbo on your truck, or messed up when putting the turbo back on. I'd be more than a little concered.
