cam sensor question - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-07-2007, 07:20 PM Thread Starter
cam sensor question
i need 2 order the cam sensor for my 00 f-350. i need to know if there are different ford part numbers for it or is there only one sensor for the 7.3? any help out there?
fordme is offline
post #2 of 7 Old 03-07-2007, 07:29 PM
Desert Shield/Storm Vet
vitalidle's Avatar
You will need the 97 to 03 cps. Im not sure of the part number. I will see if I can find it for you.
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
post #3 of 7 Old 03-07-2007, 07:31 PM Thread Starter
u rock! thanks for all your help so far
fordme is offline
post #4 of 7 Old 03-07-2007, 07:35 PM
vitalidle's Avatar
Here ya go read this thread explain everthing about r&r and the part number http://www.powerstroke.org/forum/7-3...procedure.html
Auto 93,000 miles
DP Tuner F5
post #5 of 7 Old 03-08-2007, 06:21 PM
Contact your local International truck dealer.
I just bought one for my 99 for about 100 bucks less then from ford.
nickl is offline
post #6 of 7 Old 03-10-2007, 10:24 AM
I put the stocker back in mine...I tried the international and I went through 2 of them in a month...SOmething about the didstance between the ford part and the international one...Put a stock one back in..no problems..for about a year now..
slvrtundevl is offline
post #7 of 7 Old 03-11-2007, 06:30 PM
you can get them on ebay for $50.00
billy2006 is offline
