Cam position sensor question - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-06-2007, 06:25 PM Thread Starter
Hi there,
Ive been reading about people's cps problems and am looking for alittle reassurance before I go out and buy a cps. My 00 powerstroke will start up, run for approx 5 - 7 min and shut down asif I had turned the key off, then cant' start for about 20min. Oil level is fine, got fuel, truck is indoors so no gelled lines. I have noticed that people are saying there trucked would chug alittle before it died. Mine just shuts down. Does this sound like the cam positioning sensor?
fordme is offline
post #2 of 6 Old 03-06-2007, 06:32 PM
Brian's Avatar
how old is the fuel filter? and welcome the the forum!
brian
05 f350 crew, longbed, 4x4, 68k, lariat
Brian is offline
post #3 of 6 Old 03-06-2007, 06:33 PM
Desert Shield/Storm Vet
vitalidle's Avatar
Yeah it can just shut down also here is a thread for ya to read http://www.powerstroke.org/forum/7-3...procedure.html
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
post #4 of 6 Old 03-06-2007, 07:04 PM Thread Starter
the fuel filter is new, I changed that in hopes of a solution too lol.
vitalidle- thanks 4 that link, that will help.
fordme is offline
post #5 of 6 Old 03-06-2007, 07:06 PM
vitalidle's Avatar
You bet. If you replace your cps look at ebay. I bought my spare for 58 bucks off ebay
Auto 93,000 miles
DP Tuner F5
post #6 of 6 Old 03-06-2007, 07:09 PM
vitalidle's Avatar
I bought from this seller and received it in 3 days.eBay Motors: NEW FORD OEM POWERSTROKE 7.3 DIESEL CAM SENSOR 97-03 (item 330095234996 end time Mar-11-07 20:00:00 PDT)
Auto 93,000 miles
DP Tuner F5
