ebpv question???? - Ford Powerstroke Diesel Forum
Old 03-06-2007, 04:32 PM
ebpv question????
Anybody clean out the sensor line after being clogged and still have the
same problem. I replaced the sensor to its was looking pretty bad. I should
have just bought the eliminator.
My question is: If I have any leaks at all the sensors going to give a false read correct?
Could it still be hanging up in the pedistal?
I'll take any help I can get...THANKS
Old 03-06-2007, 04:36 PM
Desert Shield/Storm Vet
Not sure, but I just unplugged mine. It will throw a soft code meaing no light. You can buy a code eliminator from dfuser works good. I don't miss the ebpv at all in fact Im getting rid of it all together this weekend
Old 03-06-2007, 05:38 PM
Almostdunfukinwidit
ebpv sensor location
is it on the front of the turbo pedastol in the middle the two wire one am i correct
Old 03-06-2007, 05:43 PM
Yep sure is
Old 03-06-2007, 05:45 PM
There is a metal for lack of a better term clamp that holds the plug together. Make sure you flip it back before ya pull the plug
Old 03-06-2007, 05:56 PM
Almostdunfukinwidit
Thats what i thought
thanks buddy
Old 03-06-2007, 06:01 PM
You bet! Makes a huge difference in power no more hissing and only takes a 5 more minutes to come up to normal op temps.
Old 03-07-2007, 03:45 AM
Send a message via Yahoo to Pony65hd99
So, Unpluging the ebpv sensor will keep the ebp valve open at all oper. temp's ?
Can this methode be incorperated with the EBP exaust break mod on this site ?
Thanks
