Injector Installation - Ford Powerstroke Diesel Forum
Old 03-06-2007, 01:47 PM
First thanks for all the help with the bad Glow Plug. Got that bad boy out. Ok here is my next question. Injectors are due back from the rebuilder. Ford manual recomends that after the injectors are installed, before you install the glow plugs, crank the engine off soliniod to clear any fluids from cylinders. I did drain all oil galley's by pulling the drain plugs. Just want to make sure I am understanding Ford. Any suggestions to help!
Thanks Again
Old 03-06-2007, 03:26 PM
International Threat
There's a writeup in the techfiles you may want to check out. As for your specific question - DJ, Stroke, or Marc should be by later to help you out!
