Fuel Filer drain Valve leaking? - Ford Powerstroke Diesel Forum
Old 03-06-2007, 10:30 AM
Any of you guys ever had trouble with the fuel filter bowl drain valve leaking? I just noticed mine is starting to leak. Any good ways of getting it to reseal up? I assume it just didn't seat good or something when I did the fuel filter so I opened and closed it again today and I will see what happens. I figure it can't be good for air in the system and it's starting to make a mess of the underside. Thanks.
-Aaron
Old 03-06-2007, 11:34 AM
Powerstroke Techie
Havent seen this in a about a month. Very commmon though, either go to ford and get a new valve about $50, or you can get the o-rings of off the web for about $5. Remove the valve install new one or replace the o-rings.
Old 03-06-2007, 12:01 PM
Cool thanks. I guess I should have searched this one. I usually do, but haven't seen it mentioned since I have been on here (about a month) and wasn't too sure about how to search that one. Thanks for the quick reply.
-Aaron
Old 03-06-2007, 12:09 PM
Desert Shield/Storm Vet
Here is a link to help you out if you want to tackle it yourself Separator Valve Rebuild
Old 03-06-2007, 12:15 PM
very simple to fix. just get an o ring kit and just replace the two o rings in the drain valve. also get alittle bit of grease to seal and hold the o rings in place. i fixed mine about 3 months ago.
