Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Motor Problems
Old 10-08-2009, 06:35 PM
sawyer1 sawyer1 is online now
wicked wheel install went bad
New in cab video on third page.
So tried to do the install today turned out i already have the wheel. took off the housing the wastegate the up pipe and the down pipe thought i made sure everything was on tight but i drove the truck and my turbo is screaming loud and no real boost and no power sounds almost like a siren. Please help if u can its hunting season and i need my truck back
Old 10-08-2009, 06:59 PM
RRonning1984 RRonning1984 is online now
Heavy Equipment 911
Have you verified that all of your boots are tight. that is usually the most common cause.
Old 10-08-2009, 07:04 PM
03f250stroke 03f250stroke is offline
agreed..one of them boots could have ripped while taking them off or even had a rip it in and you just broke it though taking it off.
Old 10-08-2009, 07:12 PM
Marty Marty is offline
International Threat
Please be a little more detailed...
Originally Posted by sawyer1 View Post
So tried to do the install today turned out i already have the wheel.unless you or someone else installed it, you don't. took off the housing the wastegate the up pipe Why did you take the uppipe off?and the down pipe Why did you take the downpipe off?thought i made sure everything was on tight but i drove the truck and my turbo is screaming loud and no real boost and no power sounds almost like a siren. Please help if u can its hunting season and i need my truck back
Answer those questions and then we'll go from there.
Old 10-08-2009, 07:59 PM
I bought the truck used so i guess that person put it on the new wheel had the same markings.
unclamped the up pipe so icould get the turbo off could not get it off so we unbolted the down pipe to do the screwdriver technique. this was all before i realize the turbo was the same. the wastegate had to come off for the housing to come off and the waste gate went on real easy.
the boots looked good ill check them out again but its 10 degrees out and snowing ill do it tommarow.
Hope this helps. The Elk are waiting to be killed!!
Old 10-08-2009, 08:09 PM
Nally7.3Powerstroke Nally7.3Powerstroke is offline
it would have been much easier to just take off the wastegate, take off the intake housing, and get the wheel off that way instead of removing the whole turbo, thats the way I did it and it took no time at all. the sound your hearing is probably normal, my new wheel whistles very loud as well, it realy gets going at around 15 pounds.
Old 10-08-2009, 08:13 PM
I never installed the new wheel its just very loud no power and poures black smoke with no speed?
Old 10-08-2009, 08:26 PM
So you never took the turbo apart?
Old 10-08-2009, 08:29 PM
Just the pipes and the housing lifted it off the pedistol but never all the way off then realized that i did it all for nothing when the wheel was the same.
Old 10-08-2009, 09:23 PM
texasredneckjae texasredneckjae is offline
i would check your boots. or install new boots.
