Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Motor Problems
  #61 (permalink)
Old 10-19-2009, 09:29 PM
sawyer1 sawyer1 is offline
Originally Posted by Austinj427 View Post
Uppipes dude. 100%
Call up Dennis at ITP, he will get you a set real fast. Even if that coupler feels tight it is leaking, my truck pushed 4-9 psi for several months trying to avoid buying them. First time out with the chip, I blew the boost gauge tube and wastegate tube right off. I had to use some tape.
Why would it be making the whine siren noise no soot on up pipes either. I dont understand why i would need the pipes when it was fine for 10 years with same stock uppipes.
  #62 (permalink)
Old 10-19-2009, 09:32 PM
southern7.3 southern7.3 is offline
Powerstroke Fanatic
I wouldn't think your up pipes are leaking if you didn't have soot everywhere.
  #63 (permalink)
Old 10-19-2009, 09:33 PM
jesilvas jesilvas is offline
Oh yea, forgot the WW was already on.
  #64 (permalink)
Old 10-19-2009, 09:45 PM
Never had a wicked wheel the one i was going to replace my stock wheel turned out to also be stock so this whole problem was caused for nothing............$%#& ME
  #65 (permalink)
Old 10-19-2009, 10:06 PM
Joel Joel is offline
My truck was making a the exact same sound, I thought I was getting pulled over by the cops the first time it happened. It kicked in at about 15 PSI and got LOUD as i got up to 28, wouldn't do it unless under load. No real power loss that I noticed. It happened the one and only time I stretched out my oil change to 6000 or so miles. I changed the oil and the noise almost completly went away. So, when is the last time you changed your oil?
  #66 (permalink)
Old 10-20-2009, 06:14 AM
Oh now that suggests the bearings in the turbo.
  #67 (permalink)
Old 10-29-2009, 01:31 PM
Well put the new turbo on and solved the problem my turbine was just to beat up thanks for all the help!!!!!
