Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Motor Problems
Old 10-07-2009, 04:41 PM
daveyburt daveyburt is offline
wandering idle
hi..
I've got a 01 7.3 on which the idle wanders a bit. it's barely noticeable on the tach. -like un-noticable unless you really stare and concentrate. it happens in a regular interval.
-new fuel filter, CPS is pretty new and it did it before i installed the new CPS. What is that sensor on top of the motor between the alternator and the lift hook....is that the ICP?
is that a possible suspect?
thanks!
Old 10-08-2009, 04:48 AM
morning bump
Old 10-08-2009, 10:51 AM
ajpu1983 ajpu1983 is offline
yeah the ICP is a 3-wire sensor on the front of the drivers side head. Unplug it and see if the idle clears up. if so it's the sensor.
Old 10-08-2009, 01:10 PM
ok, i'll check that. from what i hear if it has any oil in it, it's bad....thx!
If anyone else has any guesses, please share.
Old 10-12-2009, 08:24 AM
n20 n20 is offline
Did you ever find out anything on this?? Mine does the same thing. A noticable surge in noise and very slight feel in the seat but can't ever see it on the tach.
Old 10-13-2009, 04:47 AM
-Glad to hear I'm not alone
No, I haven't had much time to play but, I hope to soon and will update the thread with the result.
Old 10-15-2009, 02:15 PM
-just unplugged the ICP while idling and the idle changed pretty drastically so, i'm assuming the sensor is working. the idle lowered a good bit. idled smooth but lower....and my unplugging it tripped the SES so....i'm guessing it's not the ICP
did you try n20?if so, what happened?
Old 10-15-2009, 02:42 PM
n20 n20 is offline
i havent had time. I thought if it changed for the better the sensor is bad?? Did it change for the better or worse?
Old 10-15-2009, 03:00 PM
idle dropped considerably from the normal 700 so, that sounds like a change for the worse.
Old 10-16-2009, 03:17 PM
update:
i had my truck @ ford for the cruise ctrl recall and talked to the diesel tech. He believes it's ICP related.
n20: if you do it before i do, please let me know if it smooths things out....
