1999 psd loss of boost and loud hissing sound ???? - Ford Powerstroke Diesel Forum
Old 03-04-2007, 07:30 PM
My Truck Is A 1999 Psd And I Can Be Driving Down The Road And Feel The Loss Of Power Then Look At My Boost Gauge And I Have No Boost... Then I Noticed A Loud Hissing Sound Any Help Or Suggestions...thanks
Old 03-04-2007, 07:51 PM
i have a 96, when at 65mph i have only 5 psi of boost. if i were to let off the throttle, i have no boost. it might not be ur turbo. check codes if u can. what r u doing when this happens??? towing,cruising etc..........
Old 03-04-2007, 09:25 PM
Nuckin' Futz
hey man that sounds like the classic closure of your Exhaust back pressure valve. If you go into the 7.3 tech files and read the winter what to expect from your truck it explains this device. If you have no codes or anything i wouldn't be worried about it.
Old 03-05-2007, 03:48 AM
ADMIN AND TECH
sounds to me like you blew off an intercooler tube possibly ,would be very ow on power and no boost
Old 03-05-2007, 04:54 AM
Fishing Fanatic
Check you intercooler tubes, clamps. Do you have boost at all?? Or does it just do this every now and then, or when it is cold?? If that is the case, it is probably the EBPV, closing up on you to keep the truck warm. You could disconnect it if you want, or take off the turbo and remove it totally! Just my two cents!!
Old 03-05-2007, 04:38 PM
It Has Only Done This When Cold So Far... Where Is This Line At I Need To Disconnect? Thanks
Old 03-06-2007, 03:07 AM
ADMIN AND TECH
now you tell us, just kidding , definitly ebp valve shutting off
Old 03-06-2007, 04:05 AM
Fishing Fanatic
There is a connector at the bottom of your turbo. If you have a Haynes or Chiltons manual, you can look it up. There should be some other threads on this site with the pic of the connector. Good luck with it!
Old 03-11-2007, 07:31 PM
Feedback Score: 7 reviews
Send a message via AIM to dereku
I have a 96 7.3 and im not too familiar with the 99 but im sure their all about the same, i had that problem once and i noticed on the outlet side of the intercooler just before the tube reaches the engine there is what looks to be a vacume hose running to a sensor and if that fell off that could be it
