Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Motor Problems
Old 03-04-2007, 01:34 PM
nickl nickl is offline
Engine missfiring and spitting smoke
I am goning to try and describe what my truck started doing and hope someone will have some advice.
Last night driving on the hwy. at about 70mph, the truck was running great. I slowed and moved around a car and while accelarating I felt a hesitation and sounded like a miss. It imediatly went away and all was fine. In the span of about 6 miles I exited the hwy going to my stop and slowed for the turnaroud, the truck started to idle rough and not run well. Drove 2 blocks to my stop and it felt like it was going to die. Pulled in the parking lot, rough idle and when you would give it any gas it would sputter and miss like crazy.
This morning I checked the air filter for blockage and the exhaust output felt normal at idle. The idle this morning was pretty smooth and normal sounding.
I attempted to drive home from Houston to Austin. The truck would run about 50mph/ about 2000rpm with the overdrive off. This is the most I could get out of the engine. If I gave it any more fuel it would sputter and miss and white smoke would come out of the exhaust. Almost like raw fuel was being dumped into the engine.
The truck got to the point of not wanting to go anymore and now barely wants to idle.
Not sure where to go from here, Injectors?? Fuel Pump??
Also the check engine light never came on, neither did the fuel in water light.
The last time I got fuel was in Austin friday night before I drove to Houston.
Made it down there with no problems.
Thanks for any advice anyone can offer.
Nick
Old 03-04-2007, 01:42 PM
vitalidle vitalidle is offline
Desert Shield/Storm Vet
Check this thread out it might be your problem?7.3 Cam sensor replacement procedure
Old 03-04-2007, 01:45 PM
sldghamr sldghamr is offline
had a similar problem a couple years back. ended being the fuel pump. better check with a grease monkey before you start throwing $ at it.
Old 03-04-2007, 04:14 PM
thanks for the responses, I will mostlikly have it checked out.
If anyone else has ideas please let me know.
Thanks
Old 07-01-2009, 07:11 PM
johnmere johnmere is offline
DID YOU FIND THE PROBLEM
Hey my 97 is doing the same thing and it is to where now I can't go far because the miss is so bad. It will run for a mile and then I hit a hill and it runs out of fuel and starts missing.
Old 07-01-2009, 07:18 PM
jcs jcs is offline
You might want to start a new thread this one is two years old lol but i would start with the basics check the fuel filter and if its been a while or dont know the last time it was replaced you should just get a new one check the oil look for any oil or fuel leaks and use a good scanner to check for codes and welcome to the ORG.
Old 07-02-2009, 10:08 PM
chucksdieselwork chucksdieselwork is offline
i have a 98 f350 and it keeps throwing a misfire code in two cyclnders and a low turbo boost code could this be the same type of problem as stated here?
Old 07-02-2009, 10:11 PM
but if not what do you guys think on one of the sensors is bad? if so which one or one's
