wont start.. fuel problem
ok i did all my fuel lines ( from tank to pump at hte motor ) now i went to start and we were holding open hte bleeder valve on the filter adaptor and no fuel came out. also when we did it with the valve closed then pushed it in with the truck off the pressure wasnt very high?? WHAT DO I DO??????
can i get someones phone number that knows maybe and i can call you when im out there and see if we can figure it out? THANKS GUYS! jeremy |
hey, when i changed my engine out in my 99.5. i put the fuel lines on backwards down there on the cross member on the drivers side. im sure u know what im talkin about....... anyway. the filter housing was not filling up and it would squirt a tiny bit of fuel through the return line into the filter housing and then stop...as soon as i changed the lines back it filled right up. the fuel delivery line is the bigger line that goes into the filter housing at the bottom. i dont know if you changed one line at a time or took them all off at the same time but i hope u get it figured out.
