INJECTOR CONTROL MODULE OUT - Ford Powerstroke Diesel Forum
post #1 of 10 Old 09-25-2009, 07:43 AM Thread Starter
Last week my truck lost all power while I was driving, took it in to scan for codes and the mechanic says that the injector control module needs to be replaced. He said it would be a $1000. How hard is this to replace and where is it located? Any info would be appreciated.
CARLFLORA is offline
post #2 of 10 Old 09-25-2009, 07:56 AM
george.ratliff's Avatar
hahaha im going throught the same s**t man
96 F-350 XL
CrewCab Long Bed
7.3L Powerstroke
Built Auto Tranny
MBRP Turbo back exhaust system 4"
Straight pipe!
Isspro Gauges.
Boost, Pyro, Tranny temp.
Tint
20% up front 5% in the back
?!?!?what happened to the map logo?!?!?
george.ratliff is offline
post #3 of 10 Old 09-25-2009, 07:57 AM
you can go to ford for one for like 1000 dollars or try and find a used one on ebay or something look for the DMI
96 F-350 XL
CrewCab Long Bed
7.3L Powerstroke
Built Auto Tranny
Straight pipe!
Isspro Gauges.
Tint
post #4 of 10 Old 09-25-2009, 07:59 AM Thread Starter
I will check ebay out, I refuse to go to the dealer
post #5 of 10 Old 09-25-2009, 08:30 AM Thread Starter
I looked on ebay and the only thing that pops up is "injector driver module," is this the same thing as the injector control module?
post #6 of 10 Old 09-25-2009, 08:31 AM
yes thats what it stands for IDM = injector driver module
96 F-350 XL
CrewCab Long Bed
7.3L Powerstroke
Built Auto Tranny
Straight pipe!
Isspro Gauges.
Tint
post #7 of 10 Old 09-25-2009, 08:44 AM
Shaking the Bush Boss
CHUCK's Avatar
i had the code come up for the IDM...wasent the IDM! Take it to someone who has a scanner that can watch the sensor values....b4 you replace the IDM. Mine wound up being the IPR valve going south
Chuck
CHUCK is offline
post #8 of 10 Old 09-25-2009, 09:00 AM Thread Starter
I will double check on getting it scanned again, but my mechanic is very honest and knows his stuff, but I will ask about watching the sensor values.
post #9 of 10 Old 09-25-2009, 09:26 PM
You could also check to see if the connector is loose or corroded...........it's in the drivers side fender behind the wheel well liner.
If you really do need one you can get a reman here:
OEM Computers For Ford By Auto Computer Exchange
bigb56 is offline
post #10 of 10 Old 09-26-2009, 09:38 AM
Powerstroke Techie
alabamafrog's Avatar
I bet you could find one on car-parts.com for around $100. It is a bit of a pain to get to, it is right behind the F-250 badge on the drivers side. I scratched my arm all to hell trying to reach it up in there between the plastic skirt and fender.
However, I agree with being sure the IDM is the real problem. When you say lost all power, is it still that way? Does the wait to start light come on with the key? Does everything work and the engine turn over fine just doesn’t fire?
You can check to make sure the fuel pressure is good and the HPOP pressure is good for free before replacing the IDM.
“Government, even in its best state, is but a necessary evil; in its worst state, an intolerable one” (T Paine)
Government cannot give anyone anything without stealing it from someone else. (A Frog)
alabamafrog is offline
