Very rough idle on startup in park not in nuetral?? - Ford Powerstroke Diesel Forum
Old 02-27-2007, 10:13 AM
I have a '96 F250 7.3L Powerstroke that starts easily but idles very rough(loping) in "park" but when I put it in "neutral" clears up immediately. Doesn't matter if it is cold or hot. I am in coastal area of Texas with no cold weather to speak of (rarely freezing) If I start it in "neutral" the problem doesn't occur at all. Any ideas? Does this almost every time so I've gotten into the habit of starting it in neutral.
Old 02-27-2007, 04:02 PM
BIG TRUCK, SMALL DRIVER
I don't know much about autos, but Welcome to the Forum!
Old 02-28-2007, 08:13 AM
Powerstroke Techie
Send a message via Yahoo to gbear
Just a wild guess
I would research and check the "MLPS" Manual Lever Position Sensor. These sensors feed a signal to the PCM about the gear shift position. I do know there are problems with transmission operation related to this sensor, but I am not real sure that the engine tuning could also be effected. The gas motors change idle speeds with this sensors position. but I just don't not the control stratagy with reguard to diesels.
Jim
Old 02-28-2007, 08:18 AM
Powerstroke Techie
one other thing
Have you checked for codes? If you haven't that would be a real good place to start.
Jim
Old 02-28-2007, 08:21 AM
I really haven't had time to do any troubleshooting on it yet. No I have not checked for codes.
