boost pressures - Ford Powerstroke Diesel Forum
Old 09-10-2009, 07:02 PM
boost pressures
i just put in a rebuilt turbo and up pipe dounts didnt have enough money for ih pipes in my 1999.5 f250 superduty and didnt no a turbo and up pipe gaskets can make a 7.3 almost idle as quiet as a 6.0 ..now running down the highway at 65-67 in evrey tune except 125hp i run 3-6 pounds of bosst depending on the wind and if i am pulling my boat or not its 16ft aluminum fishing boat maybe weight 2500lbs and in 125hp tune i run 2-3 and i dont running it in that tune with for along time sense i dont have a egt gauge are these normal drive pressure dont hear any boost leaks has plenty of power
Old 09-10-2009, 07:24 PM
PMR = JUNK
What?
Old 09-10-2009, 07:28 PM
im thinking im running too much boost just running down the highway under now load just at 1800 rpm
Old 09-10-2009, 07:35 PM
Send a message via Yahoo to carnival owner mikey
i just put in a rebuilt turbo and uppipe donuts and didnt have enough money for the ih bellowed pipes for my 199.5 f250 sd. i didnt know that a turbo and uppipe gaskets can make a 7.3 allmost as quiet at idle as a 6.0. mo matter what tune i run i only get 2 or 3 pounds of boost at 65 mph except on my 125hp tune even if im driving into the wind pullin my boat. i cant tell you my egts cuz ivw got no gauge. is this normal?..........i think thats what he meant
PMR = JUNK
I'd help you but i cant read that first post, it makes no sense.
Old 09-10-2009, 07:36 PM
or not
PMR = JUNK
Well if mikey is right, then your boost numbers are normal.
Old 09-10-2009, 07:42 PM
i ment running down the highway on my boost gauge i run 3-6 lbs of boost just on cruise and on 125hp tune i run 2-3 lbs of boost on cruise it just seems higher than it use to be before i changed the turbo maybe im just parenoid
Old 09-10-2009, 07:48 PM
i think youre fine
Old 09-10-2009, 07:49 PM
PMR = JUNK
holy crap dude use some punctuation. Please. Its hard to help when i cant understand you. I don't wanna read the posts 15 times to decipher what it says.
But going down the highway, anywhere from 0-5 psi is normal around 60 mph, and it just goes up from there.
