? about another truck
Hi,
I have a neighbor with a '01 7.3, I noticed he hadn't moved for a while. I offered the AE & this is what we got GEM/Central Timer B1352 Ignition Key-In Circuit Failure B1302 Accessory Delay Relay Coil Circuit Failure B1431 Wiper Brake/Run Relay Circuit Failure B1434 Wiper Hi/Low Speed Relay Coil Circuit Failure B1494 Ignition Cylinder Sensor Ground Short P3494 Cylinder 12 Exhaust Valve Control Circuit Performance we also go a P1294 & he got a P1316 (?) on his superchips but it cranks, his truck will not turn over, buzz test was fine the 1st time, but after clearing codes, it came back as P1294. He was told from another forum IDM, but he did recently put clips on his ucvh & replaced glow plugs. he says everything ohms right, but I thought I'd throw this to you as I trust u guys more then the other forums. thanks |
it cranks but wont turn over??? im confused....
yeah i'm
![]() he can't get it too start........batt ends up dyin sorry tryin 2 do 20 things here, |
well, thanks for all the input
![]() It was his IDM, we pulled mine & his truck fired right up, all codes except wipers are gone., but he said he messed with the relays, so I guess that is what that is, since his wipers don't work |
