5 codes came up - Ford Powerstroke Diesel Forum
post #1 of 12 Old 02-26-2007, 12:53 AM Thread Starter
DJM
DJM's Avatar
5 codes came up
Well I got some codes on my truck and I ended up having to get towed from up in the hills playing in the snow not much fun I know 2 are for the CPS but not sure about the others.
p0733
p1670
p0344
p0478
p0340
Truck just died all of a sudden finally after about 20 min got it goin wnet about 3 miles and dead again. Just the CPS or think more?
DJM is offline
post #2 of 12 Old 02-26-2007, 04:24 AM
ADMIN AND TECH
SCUFFY828's Avatar
p0340 and p0344 cam sensor codes ,replace cam sensor ,clear system and drive , p0733 is trans incoreect gar ratio code ,may have slipped sometime or another , i would clear system ,drive a few drive cycles and retest , the rest may not come back, if p0478 comes back its an ebp code ,clean tube going to right side manifold ,may be clogged
ITS STOCK
SCUFFY828 is offline
post #3 of 12 Old 02-26-2007, 02:37 PM
PPS
I've had camshaft/crankshaft light and my son replaced the sensor, and about a month later it comes on several times a week, so I turn it off. The truck runs just fine even before we changed out the International sensor part #1825899c93. Perhaps the part is unnessessary or giving a faulty reading? Any other opinions out there regarding this part?
PPS is offline
post #4 of 12 Old 02-26-2007, 06:17 PM Thread Starter
DJM
DJM's Avatar
Well I got the CPS and so far it worked them things are spendy.
DJM is offline
post #5 of 12 Old 02-27-2007, 01:26 PM Thread Starter
DJM
DJM's Avatar
Well now my truck is doing it again this time I only got 2 codes P1670 and P0344 Anybody have any ideas Ford isn't helping out to much every time I ask them a question about it they just say bring it in. It would be nice if they would tell me some things it could be so I can trouble shoot it.
DJM is offline
post #6 of 12 Old 02-27-2007, 01:57 PM
ADMIN AND TECH
SCUFFY828's Avatar
it is possible to get a bad cam sensor,look at your wiring close down to cam sensor make sure all wiring looks good
ITS STOCK
post #7 of 12 Old 02-27-2007, 02:01 PM
ADMIN AND TECH
SCUFFY828's Avatar
oh yeah p1670 is a electronic feedback code to pcm ,most of the time you can disregard that code , but there could be a chance there is a problem with that wire ,is only one between pcm and idm ,with the code p0344 still in system ,would definitly address that code first , then go from there
ITS STOCK
post #8 of 12 Old 02-27-2007, 02:19 PM Thread Starter
DJM
DJM's Avatar
Also forgot to mention this this all happned when I was out playin in some mud puddles not real deep ones but enough to splash water up on hood could I have got water in something? Cam sensor came out wet prety sure just oil though rubber seal was flat when it came out but had to pry on it with a screwdriver to get out So I don't think water got in nothing drained out when it came out.
DJM is offline
post #9 of 12 Old 03-01-2007, 12:42 AM Thread Starter
DJM
DJM's Avatar
Well I took it in and they said they got a fuel pump code and said they have seen it before with programers Don't know why that would make a difference Since I have had the programmer in for over 2 years. Anybody else heard of that? I know FASS makes a better pump BUt they are little over $400 Not sure what a stock one is.
DJM is offline
post #10 of 12 Old 03-01-2007, 04:24 AM
ADMIN AND TECH
SCUFFY828's Avatar
i dont agre with the programer causing any of your problem, but having a fuel pump to act up is possible , curious which code they got
ITS STOCK
