2002 7.3L Dies after warming up. - Ford Powerstroke Diesel Forum
post #1 of 4 Old 09-05-2009, 04:34 PM Thread Starter
Symptoms:
Driving along at full temp (never dies when cold) and it starts with a mild loss of power. Then within a mile it's missing horribly and rolls to a stop dead and won't even idle.
Very intermitent sometimes I can drvie for 20 minutes to 30 minutes on the freeway before it happens.
Let it sit for maybe 5 minutes fire it up and off I go.
It sets a P1211 code, Which I normally don't see. I'm running a Hypertech II program set to stage 3.
So far I've done the following:
1) New air fliter
2) New fuel filter - no screen in tank, custom mode ;-)
3) New ICP and connector installed ( Mine was leaking Oil )
4) Had that cam sensor swaped on recall. ( Can't tell what color it is? it was done at the dealer )
5) Replaced O rings in IPR ( Got the kit from the dealer )
6) Installed a kit to keep the plugs from coming undone from inside the valve covers
What next???
rlc4 is offline
post #2 of 4 Old 09-05-2009, 04:39 PM
Carbon huffing animal
SixStringMadness's Avatar
Originally Posted by rlc4 View Post
Symptoms:
What next???
DTC P1211: Intermittent high pressure oil leakage
ERIC - Tennessee Powerstrokes Chapter Director
2011 K1500 Silverado Z71 5.3L Vortec
2004 F250 Super Crew FX4 Powerstroke
1997 F250 Super Cab 4x4 Powerstroke
2004 K1500 Silverado Z71 5.3L Vortec
1999 F250 Super Crew 2WD Powerstroke ZF6
1998 K2500 Silverado 5.7L Vortec
SixStringMadness is offline
post #3 of 4 Old 09-05-2009, 04:40 PM
Send a message via AIM to BadF250Boy99
i have had a similar problem in the past
try unplugging your exhaust back pressure sensor which is on the front of the engine kind of in the middle you will see a metal tube running back to your exhaust
i unplugged mine and it quit having this issue i replaced the sensor itself and still had the issue
i believe that metal tube gets clogged with carbon and throws the sensor out of wack but if its unplugged it drives fine
BadF250Boy99
2001 Excursion limited 7.3 powerstroke
331,000 miles
BadF250Boy99 is offline
post #4 of 4 Old 09-05-2009, 04:49 PM Thread Starter
Where is that sensor?
Looking around for it, not seeing it?
What's it next to, need a landmark.
Thanks
rlc4 is offline
