Cps Sensor - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-25-2007, 04:46 AM Thread Starter
95black7.3's Avatar
Cps Sensor
Does anyone know the part # for the CPS sensor for a 95 Powerstroke?Is it the same as the 99-up?The truck does the occasional hiccup going down the road and is now starting to die at red lights,but always starts back.I am leaning towards the cps.I have already changed the fuel filter.Does anyone have any other suggestions?Thanks.
95black7.3 is offline
post #2 of 6 Old 02-25-2007, 05:38 AM
Desert Shield/Storm Vet
vitalidle's Avatar
No I believe the cps has a different part no for your year. I believe 97 to 03 are the same and 96 and below would be the same. A good place to check for a cps is ebay
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
post #3 of 6 Old 02-25-2007, 05:39 AM
vitalidle's Avatar
Oh and to Powerstroke.org.
Auto 93,000 miles
DP Tuner F5
post #4 of 6 Old 02-25-2007, 05:49 AM Thread Starter
95black7.3's Avatar
Thanks.This is a great site!!!I have found alot of helpful info on here in 2 days!
post #5 of 6 Old 02-25-2007, 05:55 AM
vitalidle's Avatar
You bet! Lots of info and great people so if you can't find what your looking for post it up and somone will help out
Auto 93,000 miles
DP Tuner F5
post #6 of 6 Old 02-25-2007, 05:59 AM
Is it even worth it???
ABOBB's Avatar
I don't know the answer to your question.. but, I will bump this thread up and say:
Welcome to Powerstroke.org
ABOBB
Aaron A. Bobb
2002 F-250 SD ExCab, Short Bed, PSD, Auto trans, 4X4
Custom tuned 6 position Chip
Whelen CSP690 Strobe Kit (Installed @ Feb Indy Strokers Rally... Thanks Adam), ZooDad Mod
COMING ATTRACTIONS:
Heated Side Mirrors, Owner Built Rear Airbag System
Owner Built Front Bumper, Owner Built Tymar Intake
Owner Built Custom Exhaust, Rear Roll Pan?
ABOBB is offline
