up-pipes - Ford Powerstroke Diesel Forum
post #1 of 12 Old 09-03-2009, 05:44 AM Thread Starter
up-pipes
Hi, my up-pipes are leaking and I'm installing a 38r in a couple days when it gets here so I wanna get them taken care of. I remember seeing an aftermarket up-pipe somewhere on the internet that bolted 2 flat surfaces together and had a little piece of flex pipe at the top instead of the stock exhaust donuts. If anyone has seen or used these I'd like your input. thanks in advance for all the help! Matt
FOR SALE
2000 F-350XLT 6sp ext cab dually
K&N cold air intake
overboost annihilater
GDS fuel spring
Valair clutch
TS chip
4" down 5" back 6" tip
isspro gauges
unplugged wastegate
GTP38R
00forddiesel is offline
post #2 of 12 Old 09-03-2009, 10:20 AM
redline73's Avatar
They are called bellowed up pipes, you order directly from a International Truck dealer. They used them stock at the Medium Duty trucks that have the 7.3 They are pricey but worth every penny, no more leaks EVER again.
I have these installed on my PSD after I had leaks from the old donuts. DO NOT replace the donuts and use the old pipes they get warped after all the exposure to the high temps.
Blows my mind why they put them in the medium duty trucks from the factory, but ford didnt want them on their trucks, its all a reliability issue. With the Donuts its innevitable that you will have to replace them, with these you never have to touch them again.
It also makes turbo removal/install ALOT easier. If you install a turbo once on these engines its a PITA to get the collector to mate up to the turbo, with the bellowed pipes you have room for the pipes to flex where you want without completely unbolting the up-pipes from the collector/manifold.
Ford 7.3L Powerstroke Bellowed Turbo Up-Pipes Bellow
Here's the link to the site that you can order them from, or just go to your local international dealer.
Good luck!
-01-F350-Lariat-CCSB-4"lift-35"Xterrains-BTS Trans-Tuned by Cale
-98 Big Tex 40' gooseneck
-93-GMC-Topkick-Caterpillar 3116/Cummins 6BT swap-
Too many other daily drivers to mention
redline73 is offline
post #3 of 12 Old 09-03-2009, 10:36 AM
I need money...
CADASH's Avatar
Diesel Innovations has a very nice looking set as well!!
Diesel Innovations - Products
ITP diesel has another set too!!
ITP Diesel, LLC
2002 F-250 Lariat CC 4x4
"Im Dan,my tranny hates me no more!!"
AFE Stage 2
Power Hungry Perfomance Custom 6 Pos chip
Suncoast tranny
EBPV Deleted
Isspro Boost,Tranny and EGT
4 Inch Turbo Back Straight
Air Dog 150
H2E
Adrenaline HPOP
6.0L Tranny Cooler
4 inch Rancho lift
FS-2500
Fluidampr
CADASH is offline
post #4 of 12 Old 09-03-2009, 10:39 AM
International Threat
Marty's Avatar
The 1 peice uppipes are sweet.
2001 F250
11.62 @ 115.79
Owner of Marty's Diesel
Elkton, Maryland
Marty is offline
post #5 of 12 Old 09-03-2009, 10:49 AM
redline73's Avatar
I could be wrong but I thinkit looks like the trans would need to be removed to go with the 1-piece pipes.
post #6 of 12 Old 09-03-2009, 11:09 AM Thread Starter
Thanks for all your help i just ordered a set of the international ones. Now just cant wait to get them and put them on with my new 38r
FOR SALE
K&N cold air intake
GDS fuel spring
Valair clutch
TS chip
isspro gauges
unplugged wastegate
GTP38R
post #7 of 12 Old 09-03-2009, 11:32 AM
Other vehicle is an F250
Hank's Avatar
How much? Where from? I need a set too.
2001 F250 Lariat Crewcab, Automatic, 4X4
(Late '99 Regular Cab Work Truck)
6.5" Pro Comp Lift ~ Traction Bars ~ Son-Built Sliders ~ 16" Pro Comp Xtreme Wheels with 35" BFG TA KM2s
4" Banks Exh.-Power Elbow ~ Wicked Wheel ~ DIY AMSOIL EaAU4090 Intake ~ PHP 6 Pos Chip ~ LowDown LED Upgrade
Stage 1 Injectors ~ HankDaddy
Mod. ~ BUILT TRANNY! 352 HP Shootin' for 375!
CAROLINA POWERSTROKE ASSOCIATION
Hank is offline
post #8 of 12 Old 09-04-2009, 08:20 AM Thread Starter
$430 with shipping. got them at Home - Black Widow Diesel
FOR SALE
K&N cold air intake
GDS fuel spring
Valair clutch
TS chip
isspro gauges
unplugged wastegate
GTP38R
post #9 of 12 Old 09-04-2009, 08:24 AM
Marty's Avatar
black widow =
2001 F250
11.62 @ 115.79
Elkton, Maryland
Marty is offline
post #10 of 12 Old 09-04-2009, 08:25 AM
nah you dont have to remove the trans to get 'em in just takes a little manipulation.........
indyF-350psd is offline
