Got Codes Pulled :D - Ford Powerstroke Diesel Forum
Old 02-24-2007, 09:42 AM
International Threat
Got Codes Pulled :D
I haven't had my codes pulled SINCE I got my truck but this is what I got.
P0238- Turbo boost sensor A circuit low high - Circuit short to power, MAP sensor
P0478- Exhaust pressure control valve high input - Plugged sensor line, stuck butterfly, restricted exhaust
P0503- Lamp malfuntion (4x4 only)
P0541- AIH (AIH Delete)
P0721- Erratic signal, sensor, intermittent circuit (had a bulb out)
P1211- ICP pressure above/below desired (10K)
P1249- Waste gate steady state failure - GND short, plugged hose/port, solenoid, actuator
I'll delete them and see what comes back up afterwards.
