96 died and wont start
i have a 96 powerstroke with 4 in pipe al the way, ts chip,intake,
i was coming out of the car wash when my truck stalled and wont restart, changed cps, there is no smoke coming out of exaust at all just keeps cranking i have no oil pressure while cranking...wait to start light stayes on for a long time no matter how many times i warm the plugs id there even warming... checked all fuses |
Hi there and WElCOME!!!!!! I'm kinda new to the 7.3 world. I've learned a lot just reading on here. There's a lot of good information and a lot of tech help that is priceless. Have you checked to see if you have fuel presser. If it's not smoking it may be a fuel problem. I'm not a tech just my 2 cents worth. Ha!! One of the guy's will chime in soon I'm sure to help. Again welcome and good luck.
99 Red Stroker
does the tach register while cranking. Check fuel Pressure too...there is a little shrader valve on the side of the fuel bowl that you can use to check that. Any codes? It sounds like you ECm isn't telling your injectors to fire.
i do have fuel pressure
