Vacuum Pump Replacement - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-28-2009, 09:05 AM Thread Starter
Hey all. I was driving to Palm Desert yesterday and my a/c vents stopped working except for the defrost ones. Talked to a buddy and he said the electric vacuum pump either went out or has a leak etc.
Long story short, the fuse blew out. It looks like a battery might have exploded awhile back and theres corrosion on the terminals and the guy that check it out said the vacuum pump has corrosion on it too which might've made it blow the fuse. He put a 15 amp fuse in there and said that should help it but that the electric vacuum pump needs to be replaced.
My question is everyone I've talked to wants to charge $200 for the pump plus $90 and hour to fix it even though everyone has said it'll only take 5 minutes.
First question is: I found one on ebay for $100. Does this look legit? It doesn't say OEM which I'm not thrilled about. 01 02 Ford F350 SD V8 7.3L Diesel Electric Vacuum Pump:eBay Motors (item 310160512121 end time Sep-06-09 17:15:38 PDT)
Also, is there a write-up somewhere on replacing the pump or can someone tell me what the basic steps are?
Thanks,
Clint
diestwood09 is offline
post #2 of 3 Old 08-29-2009, 07:55 PM
6.0AWG's Avatar
Same thing happened to me
Check out this link
How to: Replace your electric vacuum pump - Powerstroke Nation
MBRP cool duals, AFE Mega Cannon, AMSOil bypass oil filter, External transmission filter, Baldwin Coolant Filter, Alpine IVA-W205 with Blackbird GPS, EGR Delete, custom side marker lights, Irridium Satellite phone, Backup camera, toolbox with 40 gallon fuel tank, levelling kit, Fumoto, CCV Mod, Zoodad Mod
6.0AWG is offline
post #3 of 3 Old 08-31-2009, 08:53 AM Thread Starter
Thanks for the post. Looks pretty easy. What do you think about the link for the ebay part? Look OEM/legit?
