so my truck shut off about 2 minutes after starting it the other day, it started stumbling a bit and then it just cut off. Hasn't started since, I put a scanner on and recorded a crank to see what was going on and here is what I came up with. does the pressure relative to the % the computer is commanding look normal? anything else I should be looking at in the datastream? before I put a scanner on it I replaced the batteries, topped off the oil and replaced the CPS (didnt realize the 2002's didn't show cranking RPM on the dash).
Edit, cant really read the thumbnail,
top Pid is RPM, 2nd is InjCtlPr(psi), 3rd is InjPrsReg (%), bottom is just the voltage for the ICP
