My 2000 f350 7.3 just massively took a dump on me the day I need it most.
I was hooking up my plow yesterday before the storm and I had it running for about 15-20 minutes all was well. backed out put it into place and it started to clack? Louder than before.. So I wanted to see wth.... started pulling out of my driveway and it gradually got worse and worse until it just died.
Now when cold it starts up fine but seems to have a minor hiccup which may be a misfire. A minute later it begins to get worse and worse and begins to die. And then dies after about 10 minutes.
It restarts but runs like crap. If I let it cool off it will run better but goes back to running like crap. To where it barely has power to move
My oil pressure is good. I cleaned the fuel pickup screens (they were a mess)
No check engine light comes on at all.
I unplug the icp and it comes on immediately. Plug it back in and after about 20 seconds it goes away.
I deleted ebpv (with new pedestal)
Blow by isn't bad. Oil seems to be good recently replaced with rotella. Doesn't have a fuel smell....
I read much about injectors failing but it seems like half the engine failed.
And that would usually pop a cel right?
