Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Motor Problems
Old 08-14-2009, 08:58 PM
ygrold ygrold is offline
no power, bad mpg
'97 7.3 won't run over 60mph, & only 7mpg.
Old 08-14-2009, 09:04 PM
OregonStroker OregonStroker is offline
prob a stuck exhaust back pressure valve. does it sound weird? like a jet kinda?
welcome to the org btw. someone will help you.
Old 08-14-2009, 09:10 PM
Nally7.3Powerstroke Nally7.3Powerstroke is offline
heres a bump for you
Old 08-31-2009, 08:50 AM
Black&Gold Black&Gold is offline
my MPG's have gone down the drain and throttle response is horrible, i have the edge evo 2. the only codes that i can pull are p0472 and p0470, both having to do with the EBV, so i am thinking mine might be stuck about half way, it doesnt make the jet noise like when its cold and im just starting it up but it doesnt sound normal... could this be the ebv sticking or am i crazy? not trying to thread jack, figured same problem and i could bump it up
Old 09-08-2009, 10:33 PM
ya dude. Totally the EBV.
Old 09-08-2009, 10:43 PM
97 golden stroker 97 golden stroker is offline
could be bad fuel too. but if it is the ebv you should cut the thing out if you dont live in a realy cold area.
