emergency fuel cut???
Where is it? do i have one? and how do i reset it?
![]() Reason being i got my old truck back to the house. cranked and fired but no throttle and tones of white smoke. It would just set and idel real ruff and only for a minute or 2. It suffered a bad front colision but nothing hit the motor that i can tell. I cut the fan belt to free up any stuck accesories. I did not have much time to realy go over it I am just trying to get ideas as wht to try when i do have a minute to tinker. |
passenger side kick panel. It should be right behind it. Should have a hole in the kick panel with it marked fuel shut off. Just put your finger in and push the red button back in. If it does not push in then it was not triggered. Or it was already reset.
Get a multi meter and check for voltage at the fuel pump with the key on. |
Is it hit on the drivers side?
It's in the passenger side foot well some where. It ought to have a yellow button to press or something. There might be a tag on it or something with a fuel pump logo. Never done a diesel this way, but I have seen it on gasoline vehicles.
When did this happen?! What did you do?
Dang Dale, i knew it got wrecked but never seen the pics.
If you are getting white smoke id say you're still gettin fuel, so the fuel pump shut off i don't think would be the issue. |
I was working on an E350 7.3l today and I had the fuel bowl out so I could reach the IPR. I pulled the fuel pump relay also, so I didn't soak the engine bay with fuel when I turned the ignition on. To test the new IPR, I just started the engine with no fuel pump, bowl or anything. The top side of the motor is a mess. The only thing I have plugged in is the engine wiring harness, ICP, IPR, and the thing started. I've done this before, so I knew it would work. The first time I did it (by accident), it freaked me the F out. |
Well thats new to me, i didn't know it would run without a fuel pump.
Suffice to say, it surprised the heck out of me when I was working on one once, and I turned it over to prime the HPOP and the thing started. I removed the fuel relay, and when I hit it, it started. I shut it down immediately, since I thought if it ran, it must mean the fuel pump was running. And since i had no fuel bowl on it, it must be filling the valley with fuel. And then I realized that it wouldn't matter if the pump is running or not, since there is no fuel bowl to get the fuel to the heads. It must be gravity. After that, I played with it a few seconds, just to see what it was doing, and see if the HPOP was leaking (the reason I had the fuel bowl off in the first place). It smoked white, and wouldn't rev worth a damn. |
