2002 F550 Class A Tow Wrecker has 281564 MI and had all 8 injectors replaced a year ago. I just replaced all the GP, UVCH, and Main engine wiring harness, to no avail. Before it wouldn't start at all, now it will start and lope horribly. Once I hit the accelerator, it will idle with no lope, but rough. If I un-plug the ICP sensor, it will start easier, but still has no throttle response, and will die once in gear, and runs rough. I ran a Inj. Buzz Test and get P1292. Any ideas? Thank you in advance!
I have a new ICP on the way, should be here tomorrow. I have not tried the CPS, the digital RPM readout on the PTO controller is not erratic, and reads like it always has, neither is the dash. I warmed it up to operating temperature and no change in the symptoms. If it was the IPR, you would think that it would run differently, correct?
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
