01 f 250 - Ford Powerstroke Diesel Forum
Old 08-01-2009, 09:52 PM
01 f 250
When I accelerate lets say more than half pedal I loose power until I let off the fuel back to say 1/3 throttle. Its Like I run out of fuel..... Just replaced filter with ltille to No help. Motor is stock , New heads, 2 wd at . Heads been on about 25k. Had to replace injector about 5k ago. used reman....any help greatly appreciated!
Old 08-02-2009, 08:06 PM
Old 08-06-2009, 01:58 AM
stumped
how can I test to see if my hpop is failing under hard exceperation?
Old 08-06-2009, 02:44 PM
Sounds like you could be sucking air into your fuel system. I have replaced a few sending units because the crack at the top and suck air under heavy acceleration. I also would check for fuel around the fuel filter. The rubber sleeves on the fuel lines can blow out too and suck air.
Old 08-11-2009, 09:59 PM
thanks for reply
I cant find any leaks......just replaced fuel filter.....Im trying to find a way to check fuel pressure from primary pump. Book says its supposed to be 15 psi. truck looses all power once this happens until you let off accelerator back to 1/3 throttle or less. If you hold it in matt it will eventually stop. I'm thinking its something electrical. No codes!!! Unfortunately its my work truck and I really depend on it. Work is slow.....sloooooooowwwwwwwwwww! I just put an injector in # 7 about a month ago, Re-man from Pensacola Diesel. I have had issues in the past with algae in the tank. Filters would come out coated. Last filter was relatively clean. I don't know if this truck has a water in fuel light. But I have never seen one come on. If someone could point me in the right direction.....Thank you!
Old 08-13-2009, 11:02 PM
update
well.....Today my truck just started running better. No more dieing out when you step on it...sigh...I think my problem is in the tank or fuel pump. any suggestions as to where to start. My knowledge is very limited on this motor and any help would be appreciated. Going to do some maintenance tomorrow by changing oil in crank case & hpop res. I wonder if someone shoved a rag in my tank....would be just my luck......
Old 08-14-2009, 05:28 PM
Did it get better when you filled up? I fixed several trucks that had a crack in the fuel sending unit in the tank and would suck air once the fuel level got below the crack. Fuel pressure should be 50 psi and watch the fuel pressure as you accelerate. If it slowly declines as you accelerate you may be sucking air into the fuel system.
Old 08-15-2009, 10:11 PM
stumped
No sir...it wasn't a fill up....(8-12) gal in tank. Truck idols fine. Anything more than 1/3 throttle for more than 2-3 seconds and its like I turned the key off untill I Release throttle to 1/3 or less. However I accidentally Left the hood up over night and it rained. The next day the trucks problem was gone. I cant imagine that having any effect on my problem but seemed weird. I'm going to try to find a fitting to check the pressure of the rail pump and see what happens when I drive it. For now.....Problem hasn't reoccurred. I'm just learning and I appreciate everyones input. Thank you!
Old 08-23-2009, 11:37 PM
Hmmmm.....
Well I have checked fuel pressure at bowl...(good). Dropped tank and cleaned out....thing was cleaner than I had imagined. Problem never repeated itself. As of yet anyway. Meanwile....I noticed that wile starting it started to drag a little. Alt output is good. batteries are about 4 years old though. I'm having to try to use this truck to make a living. I figured I would load test batteries and if they were good check starter / connections on tmy next day off. Before I could get the Time to do this I was on my way to work and in traffic at a light when truck starts making a buzzing sound from under the dash, that got my attention and I noticed that all my gages were bouncing like they were possessed. I thought to myself...man what else can go wrong when the truck stalled. No power to key or dash... nothing. Light turns green and I got 8K on the bumper....lol....by the time I was able to rob a battery out of the piece of equipment I was pulling I had some help from the boys in blue. turns out that the Driver side battery was shot. No resistance. Passenger side tested really good. Held 600 amps 12.7 v...Is there a way that this dead cell could have caused the problem I was having under hard acceleration. I know this is electrically controlled but it seams to me that the good cell would have kept the truck running. I can understand the slow starting. Could that dead cell drop all the voltage from the good one and stall the truck. Cables look good and I cant find anything corroded. new battery and it spins allot faster. Problem still hasn't reoccurred . Last but not least...can anyone recommend a diagnostic program that I cold use on my laptop To get live data from the ecm......Thanks for looking at my ramblings.... Grinder4400
