STALLING
Has anyone come across Truck stalling at low speed turns? Doesn't happen often, but it seems like when i let off the throttle to make a turn. it just stalls. doesn't kill but stalls. I hit the throtle again and away we go It might happen every turn. might just happen one time a week. the other night it was every time i made a low speed turn nothing. and its only when i turn HMM
what was the out come?
Like i said it doesn't happen often. But it still does it every now and than. sometimes its every turn. sometimes it doesn't happen for a few weeks. than it will do it 1 time and that's it. the only thing i can see that it might be, or i should say what i was thinking that if my throttle is electronicly controlled it might have something to do with that. the last time it happened i watch my rpms just go down to idle and i left off the pedal and rpms were at idle. hit he pedal again and away we went. hasn't happen since and that was friday morning. so no outcome as of yet. any suggestions where to start??
I am dealing with a similar issue. I am swiching out my cps to start with.
Same thing is happening with my truck but I finially got a code yesterday and it came out to be p0221 which is APPS sensor. So basically throttle pedal needs to be replaced. I just found out today so now im going to look around for the best place to find one. Theres 2 different ones from 99 to 03 7.3 so I need to see which one I have. Hope this helps.
I found this to just replace the sensor
https://www.dormanproducts.com/cgi-b...gory_list=:0:0 The date is states is that it fits up to 10/16/00 so Im assuming thats the truck build date correct? The sticker inside the door? Has anyone ordered from there before? |
