01 PSD ONLY 5PSI BOOST? - Ford Powerstroke Diesel Forum
Old 07-23-2009, 06:05 PM
I'm new but have been reading a lot just put on gauges and only getting 5psi on the boost gauge seems to run fine but i ride in my buddys 2000 which is chipped a a 5" exhaust and you can here his turbo spool big time barely here mine I have a diy intake and 4" mbrp turbo back have any idea? definitely not as quick as his mines a dog cc long bed
Old 07-23-2009, 06:10 PM
were did you install the guage
Old 07-23-2009, 06:12 PM
a pillar through the firewall into the tube with the T connector
If it aint a CAT itsa DOG
Check your CAC tubes for holes or cracks. I had low boost and i found 1 crack and one of the clamps on the turbo intake boot fell down allowing boost to escape. This is the #1 place to loose boost.
Old 07-23-2009, 06:15 PM
we tried the boots they look fairly new i just bought this truck about a month ago we took plumbing pvc pipe on the end of the hoses pressuried them through the cooler at 25 psi and heard no leaks
Old 07-23-2009, 06:29 PM
Have you checked the turbo?
is the truck blowing any excess smoke or any other signs that something is wrong besides low power
Old 07-24-2009, 02:40 AM
Just a little white smoke when u mash the throttle bur that's it seems. Like the power is the same since I bought the truck a month ago little better throttle response since the arir intake and turbo back exhaust I should put in here that the console also says I am getting only about 14 mpg also
Old 07-24-2009, 03:07 AM
Too cool for school
Feedback Score: 3 reviews
Send a message via AIM to taylorking Send a message via Yahoo to taylorking
Did you happen to kink the boost line?
Old 07-24-2009, 04:12 PM
no I don't think I did ran on some good country roads today and seems fine just no boost on the gauge over 5psi.
