misfire help please!!!! - Ford Powerstroke Diesel Forum
post #1 of 13 Old 07-18-2009, 05:27 PM Thread Starter
My 2000 f350 has a miss. it idles ruff, white smoke when cold and hard excel, and feals like you pulled a plug wire off a gasser. not having a good scanner i pulled all injectors in hopes to find burnt washer or bad o-ring. no luck. so I took to my buddy with a nags scanner did buzz and contrabution tests. this reveals #8 is the bad one. so i change it and it has no improvement. next I pul off UVH and bench test and everything ohmes out fine. any help ?
ddp426 is offline
post #2 of 13 Old 07-18-2009, 09:00 PM Thread Starter
ddp426 is offline
post #3 of 13 Old 07-18-2009, 09:08 PM
nccatfan's Avatar
Send a message via AIM to nccatfan
Get another buzz test done... I've often seen other injectors reveal themselves as bad when a new one has been installed. Did that with my old '94... replaced #8 (felt exactly like what yours does), didn't totally fix it (tho improvement was immediatly noticeable), only to find that the next buzz test showed 2 other injectors getting weak.
-'99 F250 7.3L PSD 4x4 (SCLB, 6-speed)
-'14 F150 4x4 5.0 CCSB
-'83 Ranger 4X4 5.0
nccatfan is offline
post #4 of 13 Old 07-18-2009, 09:13 PM
nccatfan's Avatar
How did the ohms spec out on your truck across the UVC connectors? Don't know about the new style UVCH's, but the older ones were known to melt connectors (my '94 did... Rough ride... barely limped it to the dealer for diagnostics)
-'83 Ranger 4X4 5.0
nccatfan is offline
post #5 of 13 Old 07-18-2009, 09:23 PM Thread Starter
I cheaked contanuity in the loom and gasket for broken, shorted wires while out
ddp426 is offline
post #6 of 13 Old 07-18-2009, 09:48 PM Thread Starter
The uvh is where I think my problem is. before this happen i was getting a intermitant p1316. idm circuit. I just hate to throw 220.00$ at something that cheeks out.
ddp426 is offline
post #7 of 13 Old 07-18-2009, 10:04 PM
nccatfan's Avatar
Sometimes it happens. May even be the ohmmeter has a low batt. giving false readings? Or could just be the connectors themselves... those clips sometimes get weak/wear out. Bad/weak connection= poor performance. Or too much oil gets inside a connector and shorts out.
-'83 Ranger 4X4 5.0
nccatfan is offline
post #8 of 13 Old 07-18-2009, 10:17 PM Thread Starter
thanks for the input. I'll try buzz testing again before i order the harneses.
ddp426 is offline
post #9 of 13 Old 07-18-2009, 10:21 PM
nccatfan's Avatar
No problem. Hope it helps.
-'83 Ranger 4X4 5.0
nccatfan is offline
post #10 of 13 Old 08-01-2009, 01:31 PM Thread Starter
ok, this is pissing me off! now i've replaced the uvh and gasket and nothing! i put the scanner back on it and the only codes are p1316 and p1670. the buzz test was week on #8 and contrabution says 8 too, the new injector. so now what ? I'm going to do a compresion test to rule out head gasket. but being a fresh rebuild i dont think its rings. i guss i could throw down on a new idm but if thats not it money wasted
ddp426 is offline
