Injection Control Module...where is it located
and what does it look like??? I am on HUNCH that this may be my solution...
the powertrane control module {pcm} is located behind the drivers side kick panel on 1999 through 2001 or in the engine compartment on 2002 modles black box?
The injector driver module is on the drivers side inner fender on the 95-97 trucks I dont know if they are in the same place on the newer trucks or not.Grey/silver box looks just like a pcm.Hope this helps
i have a 2001, it is located under inner fenderwell on drivers side. remove well right above tire and look up. it has awire harness with a bolt holding it in. remove that and 2 more bolts will release module. it is close to drivers door.
