Long crank time getting longer - Ford Powerstroke Diesel Forum
Old 07-16-2009, 05:30 AM
I have a 2002 250 119K owned about 2 months. Crank time used to be about 3-4secs then would start (hot or cold) idle and run fine never any smoke. Seems to be getting longer maybe 4-5 sometimes 6 secs. I suspect the HPOP. Is there an easy way to check when the HPOP is up to pressure to alow a start when cranking? That way i will know if I'm waiting for pressure to build or if something else is bad.
Old 07-16-2009, 09:12 PM
Icp bad??
check your ICP for oil in the pigtail
Old 07-16-2009, 10:58 PM
i'd check HPOP pressure, IPR and ICP
